Acura Service News and TSB's for the RDX
Looks like Sasair has been out for a while.
I will update this post with any new tsb's related to the RDX. I have combined Sasair's work and will be updating this page often.
Service News:
2006
July - New RDX uses Mobile 1
August - right power mirror problem on early VINs, software update to improve shift quality, engine won't start/immobilizer blinks
September - nothing RDX specific
October - AC fan noise cycling frequently, satin finish chrome and water spots, AcuraLink communication setup
November - roof rack weight limits, front door courtesy light lens falling off, nav map matching, software update to fix brake system problem, TPMS info
December - Nothing RDX specific
2007
January - Dead Audio Unit, Side Moulding Install Tips
February - AT solenoid, Homelink
March - Roof rack covers, DST, outside temp logic
April - Parasitic current draw, cutting roof moldings
May - HFL Locked, No sound or data from XM
June - Engine block coolant separator
July - MAF Sensor, Window Tint, TPMS
August - VSA troubleshooting, Running Fuel Tank Dry
September - Window regulator reset
October - Nothing RDX Specific
November - TPMS Info, Metallic Window Tint, SRS DTC, Nav Info, Interior Lights stay on, Security System, HFL 1 of 5
December - HFL 2 of 5
2008
January - HFL 3 of 5
February Poor Audio Quality, HFL 4 of 5
March - VSA Indicator On after repair, MIL with aftermarket intake, HFL 5 of 5
April - Can't Turn VSA Off?
May - Nothing RDX Specific
June - AIRBAG OFF Indicator Turns On and Off With Front Seat Occupied, DTC P2422
July - Excessive Parasitic Draw? Check If the B-CAN System Is Awake
August - No Communication Between HDS and VSA Modulator-Control Unit
September - Tailgate Outer Handle Not Working
November - Nothing RDX Specific
December - Nothing RDX Specific
2009
January - SRS DTCs 32-xx and 31-xx Are Strictly About the Side Airbags
February - Homelink, Power Mirrors
March - DTC P0325 Knock Sensor
April - Nothing
May - Nothing
June - Nothing
July - Broken Valve stems, Tire Sealant, XM cuts out
August - TPMS, Power Window Reset
September - DTC P0341
October - Nothing
November - Nothing
December - DTC(s) P0171, P0174
2010
January - Lower Front Door Sill Seal Is Loose or Hanging Down
February - Nothing
March - Nothing
April - Nothing
May - Nothing
June - Nothing
July - Nothing
TSBs:
Service News:
2006
2007
2008
2009
April - Nothing
May - Nothing
June - Nothing
October - Nothing
November - Nothing
2010
February - Nothing
March - Nothing
April - Nothing
May - Nothing
June - Nothing
July - Nothing
TSBs:
- 07 Base models with buzzing tweeters
- 07 Wipers Intermittantly don't park or turn off (VIN 5J8TB18..7A000001 thru 5J8TB18..7A025022)
- 07-08 Hands Free Link
- 08 Noncompliance recall Certification Label
- 08 Paint codes
- 08 TQI and new model information
- Updating the AcuraLink control unit
- Buzz from rear satellite speakers
- MusicLink
- 07 Paint codes
- 07 Brake warning light is on
- 07 Safety recall: accessory trailer hitch is incorrectly welded
- Excessive gap between accessory roof rack and roof
- 07 Immobilizer System (Type 6)
- 07 In Gear (D Position) shift-shock reduction
- 07 TQI and new model info
- 07 DST Update
- 07-08 TQI of the DVD Navigation System with voice recognition
- 07-08 Low Tire Pressure Indicator Stays On, But All Tire Pressures Are OK
- Battery Discharges For No Apparent Reason
- Key Will Not Come Out of the Ignition Switch; Roof Leaks Water
- Windshield Washer Reservoir Leaks
- AcuraLink Messages Cannot Be Read, There Is No XM Radio or Traffic, or XM Channels Are Wrong
- Load Carrying Capacity Reduced Label
- 2009 RDX: TQI Information
- The client notices that the clock shown on the subdisplay, the audio unit, or the navigation screen randomly changes time, but never by exactly 1 hour
- 07-09 Left Rear Seat Creaks or Rattles
- 07-09 MIL Comes On With DTC P1009
- MIL Comes On With DTC P0962, P0963, P0966, P0967, P0970 or P0971
- 2010 RDX: TQI and New Model Information
- 2010 Paint Codes
- Amber Brake System Indicator Is On With DTC P16D9
- Front Door Outer Handle Binds or Sticks When Cold
- Retractable Master Key Does Not Lock in Its Extended Position
- Service Manual Update: Power Window Goes Up and Reverses On Its Own,
Is Slow to Open and Close, or Squeals, Creaks, Clunks, or Clicks - No XM Sound, But XM Station Information Is Displayed
- 2011 RDX TQI
- Center Console Armrest Will Not Latch or Stay Closed
- Door or Rear Shelf Speakers Rattle, or Sound Is Distorted
- 2011 Acura Paint Codes
Zonian22
11-14-2015 01:20 PM
asahrts
09-04-2015 05:55 PM
