Speaker Help
Speaker Help
2007 RDX
I've have now lost 3-door speakers since purchase. The last one just outside of warranty. The dealer has been no help. I want to replace my speakers but I can't find what to replace them with.
I know they are made from panasonic and are a 17-CM SDR speaker, but that hasn't helped, nor has searching through the forum.
Someone out there has to have replace these door speakers and I would like to know what they used, that doesn't require any mondifications. The Speaker sites haven't been much help either.
Thanks,
Thanks,
Blown door speakers are a common Acura issue (across the board). There is an AZ member who swapped out to bigger and better door speakers; however he had to cut and remove the speaker grills and modify the door to get them to fit. I could not find his post, but I didn’t look that hard. I did find these three.
https://acurazine.com/forums/showthr...=690237&page=4
https://acurazine.com/forums/4g-tl-audio-bluetooth-electronics-navigation-294/driver-side-speaker-makes-noise-749118/
https://acurazine.com/forums/showthr...=738054&page=2
Check them out, they may be helpful.
2007 RDX
Thanks,
Thanks,
Replace withe the only 2ohm aftermarker speaker. Infinity/JBL. both are owned by the Harmin Group. The infinity Reference speakers 6x.xx/set online or ebay will work just fine. They are 2-ways with adjustable tweeters and tweeter x-over. Most TL owners that wanna continue using the ELS amp choose these as you actually gain clarity and a tad more volume due to the fact the have 95db s/n ratio. They change the door speakers and the 3.5" center channel driver. All this comes out to be a great upgrade in sound. Going to any other speaker 4-ohm will drop the volume a decent amount.
Called Acura Customer cares, and have a case number. They won't admit to anything of course.
Does anyone have a copy of the tech bulletin for the speakers, that the could post?
Thanks,
Do these speakers require any fabrication? Reading these threads it seems that most have just done the warranty exchange. If I'm going to pay I don't want to pay for the same defective speakers.
Thanks,
Thanks,
kb1rl
09-30-2015 10:17 AM
polish_pat
09-25-2015 12:24 PM
4drviper
09-23-2015 09:00 PM
rboller
09-23-2015 02:49 PM
