SiriusXM died - RDX 2007 Tech Package
The SiriusXM radio suddenly stopped working after a handsfree call. After finishing the call, XM radio is totally dead. I cannot access any of the XM channels via the XM button on the radio unit, from the steering wheel "mode" button, or voice controls. I have checked fuses and they are all intact. Does anyone know the best diagnostic procedure? I know the Acuralink Control Unit is behind the glove box, but how to troubleshoot?
Acura RDX 2007 Tech Package |
Anyone...???
To be clear, regular radio channels work, CD changer works, sound works. Pressing the XM button does nothing. Toggling the "mode" button on the steering wheel will cycle every radio mode EXCEPT satellite radio. Any ideas...?
RDX 2007 Tech / Same Problem
Raisuroketto,
Did you ever solve your XM problem? My RDX has the same problem, started yesterday. Everything works except XM, plus I can not set my clock. Dash shows wrong time. When I go to set the correct time, it shows the correct time in the setting box but won't change the dash readout. |
Did you try replacing the XM module?
