Select XM mode w/ voice command
I have an '09 Tech and the first time I use voice command to select XM2 after turning on the vehicle, I get an error with two beeps and the XM2 mode is not selected.
If I use voice command to select XM1, no problem. Subsequently, XM2 will work. If the radio was last on XM2, it will still be on XM2 when the car is turned on. I can select any other mode directly with voice command, but each time, XM2 seems to require that I go into XM1 first (not the case with the physical button).
Not a big deal, but I am curious if others have noticed this.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
