Multiple phones on HFL
Base RDX - Carbon Pearl
I am wondering if the HFL can't be used by multiple phones at the same time. I mean it hooks up multiple phones from driver and passengers at the same time.
I've paired both our phones but have only used 1 so far. I was told (and deduced from the manual) that both phones can be active and able to be used with HFL at the same time, but only 1 phone at a time can actually be used to make/receive calls (makes sense). I'll have to try it to be sure, though.
Only one phone will connect at a time. I think you can have up to 6 phones in the pairing list. For example, if you have two phone setup to use HFL in the car, The first phone that connects will be the only one that will operate. If both phones are present when the car is turned on, then it will go in order of the pairing list as to which one has priority. If phone 1 is connected to HFL, and a call comes in on phone 2, it will not come through the HFL. You would have to go through the HFL menus to switch to phone 2 in order to use it through HFL. and if you did, then any call coming in on phone 1 would not come through HFL. Outgoing is the same, only 1 phone connected at a time.
nico4k (12-13-2021)
To switch to the next phone in your paired list, the voice command is "Next Phone". The Bluetooth receiver in the RDX will try to pair to the next phone in its list. My wife and I tried it last night with our phones, and it works really well.
mlody
12-04-2019 02:11 PM
phillyguerrilla
09-26-2015 11:27 AM
