Bluetooth
Bluetooth
Hello, I have an ACURA RDX 2007, I have the technology package in the vehicle, I want to pair my phone to the bluetooth, but the previous owner before me set a password that I do not know, how may I reset the blue tooth so that I can pair my cellphone to it?
Does it ask for a password/PIN right away? If yes, then:
That's from 2007-2008 TL service manual:
HFL in RDX is probably similar, and searching for "07 RDX bluetooth locked" came up with same answers.
You need HDS or some other "powerful" scanner ( that connects to OBDII port) to perform system reset, or contact previous owner to get the code.
Honda and Acura dealerships should have a scanner, other shops might have it, but are not likely to even try to help. If you have a friend with Verus or something similar, it might work.
Otherwise you're out of luck.
Welcome to the forums.
This thread has been moved to the model specific forum for better response.
sockr1
315
06-03-2021 03:46 PM
ktuck911
14
05-09-2017 08:58 AM
gatorknight904
03-08-2017 12:34 PM
Icarus3000
12-13-2016 01:25 PM
