Beep When Remote Pressed Twice.. Beeper location or Info??
I installed an aftermaket Remote Starter in my 2008 RDX. I am able to make the car start with a Negative or Positive pulse (Selectable 1,2 or 3) or with the aftermarket remotes.
I was planing on using the Chirp or Beep modual that makes the beeping sound when the doors are locked from the OEM remotes. It sounds like the module/speaker is in or near the drivers side fender. I am looking for it because I would like to be able to use my OEM remotes to start the car.
Does anyone have any info on this part? Is it 12v? What does it look like and where is it located? Or is there a relay for it.
09-17-2015 09:01 PM
