Tire Size
Tire Size
Good evening. I have an extra set of tires that came off my 09 TL SH-AWD. They are 245/45/ZR18 Continental Extreme Contact DWS. I was going to give them to a family member who needs tires. She has an 10 RDX. Could someone please tell me what the stock wheel size is for the 10 RDX, and if the tires I have, would fit? Thanks in advance!
Factory is 235/55/18. The new to her tires would fit no problem but it may be a slightly stiffer ride with the lower profile and the speedo will be slightly off too. Nothing to worry about in my opinion though.
cobra611 (02-23-2020)
18x7.5. The tires will fit, but the diameter difference is fairly significant. Stock 235/55/18s are 28.2 inches tall on average. 245/45/18s are 26.7 inches tall on average. Pros are better handling, braking, and acceleration. Cons are harsher ride and decreased fuel economy. Theyll fit though if shes in a bind.
1.5" difference in tire height will throw the speedo off substantially as well. You'll be going slower than indicated and it gets exponentially worse with speed. So you may be off 2-3 MPH at 40 MPH but you could easily be off 5 at 70 MPH with that big of a difference. There are online calculators for that, like here:
https://tiresize.com/calculator/
Ran the calcs and it's not quite as bad as I thought, but still, not great:
![](https://i.imgur.com/zM60OMFh.png)
cobra611 (03-03-2020)
dinks07
02-28-2011 06:52 AM
