Rgular or Premium fuel?
#81
Originally Posted by Lrpba300
The two types of motor are easily distiguishable by the factory rated power output: the performance motors make around 200 hp or more in stock form and the economy motors do not make much more than 160 hp from the factory.
I only have been filling up with 93 octane fuel from Mobile, so maybe I am getting even more better performance...
JD
#82
Sporty X type
Originally Posted by newteez
Good, info, the bottom line is we have to pay a little extra for the gas. All new cars in the luxury segment require premium fuel though, which makes me believe that there may be some kind of conspiracy going on. However I agree that for this particular engine and a car that is geared towards performance there is no reason to try a lower grade fuel in it. Plus as mentioned $200 per year isn't going to break the bank.
JD
JD
#85
*snip*
"All Porsche engines are designed for premium, too, but it's not available everywhere. "Our cars must be able to drive all over the world, and so we are able to run on regular," says Jakob Neusser, director of powertrain development at Porsche's research and development center in Weissach, Germany. "You don't have to feel that a mechanical problem or anything else will happen" using regular gas, even in the highest-performance, regular-production Porsches." */Snip*
I find this section interesting. If a highly tuned and powerful car like a 911 turbo will not experience any mechanical problem running on regular fuel, I don't see what is so advanced about the RDX engine that would prevent it from doing the same.
#86
07 RDX - Royal Blue/Ebony
Originally Posted by B18Ch1ck
Even when I was a high school student, buying regular NEVER once crossed my mind.
Ah, those were the days of carefree youth and fuel grades. A time when the beer flowed like 93 octane Sunoco. Where beautiful women instinctively flocked like the salmon of Capistrano.
#87
Originally Posted by Fishbulb
*snip*
You know what, go ahead and use 87 octane. Infact, put in diesel. Its your car, and you can deal with the results.
Everyone else, please continue to use 91+ octane as these are high compression engines which REQUIRE it. Detonation is not your friend, knock is not your friend.
Lrpba300, nice avatar! Chargers are going down!
#88
#91
2016 MDX Adv/SHAWD
Just for those with some doubt....look on the inside of the gas door. It does NOT say recommened, it says Premium Fuel ONLY.
Nothing but the best 93 octane for my baby.
#92
*snip*
The fact is that most premium luxury or sports cars/SUVs require premium fuel because their engines are calibrated to utilize the premium fuel to extract the best performance possible out of the motor. Yes you can use regular fuel, but at the cost of some performance (more noticeable on some cars than others).
Even Porsche's need to be able to run on regular when premium is not available. The knock sensors built into the engine are intended to minimize the potential damage that can occur due to engine knock. However, Porsche still recommends premium because it is what the engine is designed to run on. Extended use of regular fuel in place of premium may lead to problems with the motor.
So while your quote is interesting, it doesn't necessarily prove that you can use regular fuel on a consistent basis in a motor that requires premium.
#93
It wasn't my intention to provoke a rude response. I simply thought it was an interesting quote in context of the discussion.
#94
Hey, sorry for coming across like that. Its just that this whole thread is so frustrating. The manufacturer says use premium, the car has a turbo (aka high compression engine), and the car is around $40,000 and people are trying to save some $ at the pump.
This isn't exactly correct.
Turbocharged engines are NOT high compression engines; in fact the compression is deliberately lowered because of the turbo's boost. The RDX has a compression ratio of 8.8:1. The non-turbocharged MDX has an 11.0:1 ratio. Even the Honda CR-V has a higher compression ratio (9.7) than the RDX.
#95
Prove it. The Porsche fellow alludes to nothing of the kind, and for warranty reasons, they would be firm on that point if true.
I'll certainly concede some performance losses would occur, but I remain skeptical about the engine damage possibilities.
There is marketing involved here, just as much as engineering.
#96
Any smart person wouldn't risk it either way. I personally have witnessed what using non premium gas will do in an Acura non-turbo engine that required premium. It knocks like crazy. No, I didn't put non premium in my acura, but our company uses Acuras which get filled by various people who do not know to use premium. Service department says that it is the most common problem they see at the dealer.
#97
Everything is NOT a conspiracy. Engine knocking is quite real in high compression and turbo engines especially. In order for the engine to compensate, it must detect it first. Knocking in turn destroys engine.
Law of transitive properties, Premium should be used where available for car that recommends or requires it.
Knock = Bad, Premium = no Knock(usually) No knock = good, premium = good
Seeing as the 911 has an 11.3:1 compression ratio it would be in your best interest to use at least 91 Octane fuel.
Mike
#98
Mike
I own a 1998 honda prelude, which specifies 91 octane or higher, which I bought new. I have religiously put in nothing but 87 octane since 20K on the odometer, not necessarily because I'm cheap, but because I couldn't notice a difference in how the car ran between each octane rating.
It has now just clocked over 250,000km, and has perfect compression, and recently ran a 15.4 at the strip, which is about average for the car brand new.
Mileage is unchanged etween 87 and 91.
I tend to believe the quotes from the engineers and experts in the article. The knock sensors on today's modern engines do a fine job of preventing engine damage, and the performance loss is hard to notice in most cases.
When I buy an RDX, I'll most likely start with 91, and eventually drop down to 89. If I don't notice any issues, then I'll continue with it. The oil companies make enough money already, thank you very much.
#99
Originally Posted by sasair
Prove it? I think it would be on you to prove that it wouldn't cause damage since you believe that it wouldn't.
#100
And that's why today's modern engines employ a knock sensor, which detects it, as you mention. The only exception would be that of a supercharger, which could be a bit too quick for the sensor to compensate for.
Anyways, I doubt your car will have too much problems w/ regular gas for normal driving experience, but for sure your performance will be handicapped a little. It's your choice. However, pay special attention to your engine once you start to use regular... listen carefully and if you hear any pinging or knocking, better put in better gas. Especially in high altitudes, climbing hills/mountains and in really hot weather... pay special attention to your engine. Just a friendly warning.
#101
Fishbulb, its your car, do as you wish. Again, it is not a conspiracy. IMO, it is stupid, yes stupid, to not heed manufacturer fuel advisory, especially on a regular basis. This is not to say you couldn't get lucky with one of your cars, whether it be your driving habit or an engineer suggestion.
Also, as I will say again, knock sensors must detect knocking in order to cancel it, and their will be a drop in power. Also, there is no guarantee they will be fully effective. If you go to the 3G TL section their are threads about noticeable power losses due to compensation as well as engine knocking.
If anyone wants to calculate out the maximum effective compression ratio for the RDX IIRC it is close to 12:1. But of course, a conspiracy, lets use 89
Listen, I know you know everything about the octane ratings, engine compression, detonation, knock, and forced induction, but it is especially advisable to listen to the manufacturer and stick with premium. You spent 34-36K on car, why try to save a buck on something that could potentially damage your engine?
Edit: You don't need to be an engineer to know that it is a good idea to run premium in a Porsche, especially one under boost or high compression. If this helps at all, my physics teacher was a huge car buff, very cheap, and a master technician, and he said it would be insane to run anything lower than 91 in a car with an 11:1 compression ratio. How about this, go out and buy a Porsche, put in 87, and start pushing the engine to its limits.
Mike
Mike
#102
On the contrary, I believe it would be on you to prove it since the Porsche engineers believe it wouldn't. I'm just quoting the article here.
#103
Who here cares about a quote from a Porsche engineer?
As I said, I'll use 89 in my RDX, and compare it to 91 for a time period. If I notice significant mileage or any performance/knocking issues, I'll stay with 91. I doubt that will be the case.
Anyhoo, different strokes, different folks. This is moving more from a debate regarding the points of the article, to personal suppositions.
#104
I never put regular in a car that calls for premium, but I did try the mid-grade gas on an '02 BMW (naturally aspirated) and a '95 SAAB 9000 (turbocharged). No knock but slightly lower mileage in both cases, which eliminated of some of the cost differential between plus and premium. In any event, I went back to premium.
#105
Your case with the Prelude is more likely to be an outlier than it is to be within the norm. I have heard of several cases where knock sensors fail and the end result is ususally damaged valvetrains, bent rods, and even thrown bearings.
Nonetheless, do as you please as it is your car, but don't come crying to us if something happens to your car.
#106
2016 MDX Adv/SHAWD
I trust a honda engineer that helped design the HONDA engine more than a Porshe engineer talking about DIFFERENT engines. If the $200 a year in price is worth the price of a new engine go for it IMO. I'm not putting in anything but 91+
#107
Even if the knock sensor detects the knocking properly, the result will be that the engine timing is retarded and engine output (and probably smoothness) will be reduced. Why bother paying for the RDX if you're going to handicap the engine performance? For a mere $80-100 savings a year?
My previous car recommended 91 octane, which I used. One time my wife put in regular gas and I noticed it right away (the engine performance prompted me to ask her, which is how I found out about the regular gas). The engine felt less peppy and throttle response was not good. The only thing the manufacturer noted on their website was a small (4HP) loss in peak horespower with reduced octane, and slightyl lower MPG. What they didn't say was that you felt a bigger difference through the whole power band, especially at low RPMs where we tend to be in everyday driving. After that experience, I fully appreciated the octane recommendation. If the engine mapping was optimized for a certain octane level, that's what I put in the car. I'm not interested in reduced performance for a 10 cent per gallon savings. For me that's $87 savings a year. Not worth it.
#108
I have lots of experience with turbocharged engines, and would highly not recommend running anything less than the highest octane offered in your area...usually 92 or 93 but as low as 91 in California. (for best performance and engine longevity).
For Turbo or supercharged engines, the higher the octane the better. On hot summer days, premium was sometimes not even good enough to keep the engines in some of my old cars running at max timing advance. (adding a couple gallons of 100-102 octane racing unleaded would make a big difference on track days)
#110
CITGO has 110 rating for racing: http://www.citgo.com/Products/FuelGa...ngGasoline.jsp
Or this: http://www.turboblue.com/typical.asp
#111
Originally Posted by Icealicy
Where would you find 100 or 102 octane gas? I have never seen that type of gas anywhere. Please inform. Lol. Thanks sexies, man. Lol.
#112
07 RDX Tech - Blue/Ebony
your ecu will start with a baseline for ignition advance (timing) and learn up (attempt to apply more ignition advance). once it detects knock via the knock sensor, it will pull back advance. you could theoretically create an ecu that would run on 87oct through 116oct, but it would not be ideal. the baseline ignition advance curve will probably cater to 87oct and will be able to learn up to efficiently handle 93oct. the big problem occurs when you consistently use 93oct fuel and then fill up with 87oct. the knock sensor will detect the knock that WILL happen and it will pull advance back temporarily and make a note of it. then knock WILL occur AGAIN...and it will pull advance back temporarily and make a note of it. your overall ignition advance will not be sufficiently pulled back until a certain amount of time/severity/occurences.
the argument could then be made that "well if i just use 87oct all the time, i will never have the problem." that argument is wrong also. your ecu will always try to advance up to its maximum. over time, it will slow the advancements made to where it will detect small enough knock to not cause severe damage, but it will still try to advance.
#113
so in reality, your gas has to withstand the dynamic compression to supress knock...the static compression no longer matters.
#114
Originally Posted by bradykp
the difference can be attributed to his driving difference on those tanks. MPG should not vary between octanes, there's no logical chemical reason for it to. i've already discussed this with numerous Chemical Engineers who work for a couple different Oil companies. Knocking, pinging, and engine damage is an issue with octane, but not MPG. i've been getting identical mpg with 89 vs 91. i'll try 87 also and see, but i fully expect it to be the same. (i don't have a RDX so it's not a big issue with the tsx)
one of the causes for knock is if in cylinder temperatures get too hot. richening up the AFR (ie, lower number) will add more fuel and will essentially cool the in cylinder temperatures. this will help prevent knock.
some ecu's will richen up the mixture if it detects a lower octane fuel...and in the case of extreme knock situations, may even revert to a completely different (much richer) fuel map.
richer AFR = more fuel = lower mpg.
#115
Originally Posted by s4iscool
How can you make such statements without even knowing the exact specs of the RDX turbo? 13.5 can be fine on a WRX or 1.8T turbo, but that doesnt mean you can automatically assume that 20psi will be ok on the RDX. Im sure honda did its homework and put the rdx boost right in the turbos efficiency range, but we dont know if they are pushing the upper limits of the setup or being extremely conservative.
Also, if the ecm can account and adjust for the 89 oct, and the car does not knock, it is fine. Sure you will lose optimum performance, but it doesnt mean that turbo is going to explode is some catastrophic failure . But im not advocating the use of sub 91 oct in the RDX, in fact I clearly said it is not worth the minute savings in gas price to use sub 91 oct.
As for your last statment that modern turbo cars are coolant cooled..the last 3 turbo cars Ive had in the last 5 years were oil cooled and some in part with water cooling as well. So it does help to let the car idle before shutting off if it has been driven hard.
some of the '04 STi's even knocked with 93oct! putting in higher grade gas ALWAYS got rid of the knock. granted that was an issue of a poorly mapped ECU, the fact remains the same- higher octane gas DOES resist knock better.
the ECU will account and adjust for the 89oct but it will knock doing so.
modern turbo cars are water and oil cooled. the design of modern turbo cars are such that when the car is turned off, there is a natural syphon that occurs where the hot coolant will rise to the top, and the cooler coolant will sink to the bottom...this will keep happening until the turbo and coolant are back to a normal temperature. no need for a turbo timer, but definately never a bad thing to cool it down...unless you dont like wasting gas (like me).
#116
#117
What reason would Honda have in advising more expensive fuel if it's not needed. That's a negative marketing point, not a positive. I'd love to be able to use regular but I'm taking Honda's advice (requirement) and using hi-test.
#118
Originally Posted by snorton48
Can't buy any better than 91 in San Francisco.
On a seperate note, Keep in mind that due to Cali laws, our gas is oxygenated to reduce pollution. This also makes it a bit weaker and causes many higher performance vehicles to ping. This is on top of the already lower 91 octane.
#119
Sporty X type
You all keep talking about Cali. only having 91 octane. Well, Colorado is the same way, prob. due to the high altitude in most places. It's all I'll run b/c of the turbo type engine 7 that's what the Honda engineers advise!
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
joflewbyu2
10-08-2015 11:16 AM
