Rear wheel camber?
Originally Posted by ericeash
am i an idiot or doesn't anyone know?
Camber angle:
Front: 0 deg, 10 min +/-45 min
Rear: -1 deg, 0 min +/-45 min
Not sure if negative angles are bottom in or bottom out. In any case, -1 deg should barely be noticable if at all.
yeah, i just read that myself. i'm going to put a small weight on a string and see how far away the top lip is when the bottom touches. i'll get some pics up as well. what i'm worried about is uneven tire wear. FTR, negative camber is what i'm seeing, it's when the tops of the tires are closer together than the bottom.
eric
eric
do you have anything in the trunk?
i had about 1000+ lbs in the trunk area over the weekend and there was noticable camber...ive noticed it with people in the back, as well, just not as much.
with nothing in the back, it looks pretty straight to me.
nuldabz
09-03-2015 06:49 PM
