RDX wheel specs
RDX wheel specs
Would anybody happen to know how much the stock 18" wheels weigh?
Also, I'm pondering some 19" or 20" aftermarket wheel / tire combo. Does anybody have the bolt pattern, offset, etc. I'd need to ensure a proper fit?
Tried searching but couldn't find relavent information.
Thanks!
Thanks!
Photographer
Thanks!
Thanks!
https://acurazine.com/forums/showthr...highlight=rims
The bolt pattern is 5-114. Don't know the OEM offset, but it should be printed inside the wheel.
Most of the Tire Rack wheels have an offset between 40 and 50, depending on the styling.
Try to avoid using hub-centric rings or spacers, and check that the TPMS sensors fit.
Why avoid the hub centric rings? I always stay away from spacers tho..
Photographer
Thanks DNPhotography,
Both look great!
Honestly, I have no clue what to do wheel wise.
Does your car feel any slower with the 20"s?? Any rubbing??
Thanks!
Both look great!
Thanks!
2016 MDX Adv/SHAWD
tirerack.com, i dont know if its an option on the website, i had to call to get tpms installed, they worked right away, my acura service said they were surprised usually the freq has to be programmed or something like that...idk but they work great!
rockyboy
01-25-2016 06:00 PM
DunesCreations
09-09-2015 12:03 PM
nuldabz
09-03-2015 05:49 PM
