PSA: Exhaust Manifold Damage Lower Engine Mount/Torque Mount REPLACE
These cars have a water cooled manifold that sometimes breaks. like a two thousand dollar job if it break. make sure you replace the lower torque mount/engine mount. They go bad quick, and all that movement is probably what breaks the manifold.
ALSO, if you have a broken exhaust manifold MAKE SURE YOU RULE OUT the small o rings that leak on the top of the manifold.
It's 1 larger bolt and 2 smaller bolt. you need to support the engine with a jack, make sure you put a piece of wood on it before you put it under your oil pan before you jack it up a little to support it. easy job. here a link and a picture https://www.acurapartswarehouse.com/...0-stk-a01.html its part #8
