Oil change by mileage or car reminder?
Old Oct 22, 2012 | 01:41 PM
alex77k's Avatar
Hello guys,
I have a 2010 RDX and been a happy driver for almost 3 years now.
I have a question about oil changes and general service reminders.
The problem is, my RDX's service reminders show up 1500-2000 miles sooner than what the dealer sticker (the little sticker telling when the next service is due) says.
For example, if I had an oil change at 15000, the dealer sticker will say "next service due @ 20000). But my RDX's service reminder says Oil 5%: service due now only @ 18500...
I like the car my the oil change is a bit expensive. And having the car tell me to change oil every 3000-3500 miles... wth???
So which one do you follow? The car's service minder or the dealer's sticker?
Thanks in advance...
Old Oct 22, 2012 | 01:47 PM
the MID bases its calculations off of start up's, engine rev's, and other conditions that can be found in the manual.
with a turbo motor, I would be more diligent on those oil changes!!!
Old Oct 22, 2012 | 02:09 PM
mrgold35's Avatar
mrgold35
I always follow the M.I.D. schedule for oil changes for both my TSX (+93,000 miles) and RDX (+79,000 miles). So far, I don't have to add any oil to either vehicle between oil changes.
There are times I will change my oil early; such as, when going on vacation and I don't want the car screaming at me because I'm due. Most of the time, I just follow whatever the M.I.D. tells me and it is one less thing I have to worry about.
Old Oct 22, 2012 | 03:05 PM
Mr Marco's Avatar
If the MID doesn't request a change, BUT your little sticker say you are at the "Time to change the oil" milage, then change the oil. I just had that occur on the TL. The MID did NOT display, but I noted that I was 200 miles short of due for a change, so I changed the oil.
The car might also sit for an extended period of time in your garage. All oil degrades. Soooo...If, for example, you got called back into active duty/service for some reason and you were in Fallujah for A YEAR AND 1/2. You'd want to take the car in for service and have the oil changed before you drove down to your Mothers house (just to be safe).
Old Oct 23, 2012 | 06:35 PM
DRR98's Avatar
The computer also will log the miles you went beyond the service due now indicator. A factor that could be used against you if you ever had engine warranty issues. Did you read the owners manual? This is covered in the owners manual.
Old Nov 9, 2012 | 04:53 PM
KenB350z's Avatar
Every 3000 miles, can't good wrong with that.
Old Nov 12, 2012 | 04:58 PM
wifesRDXtech's Avatar
Follow MID , found 5 qt Mobile 1 ( specs met) on the cheap at Walmart.
Old Nov 13, 2012 | 09:16 AM
Vividsi's Avatar
Ive noticed mine at 20% and ill have 1,800 miles to go before hitting 5K, I changed it only using M1 Synthetic and sure enough its pitch black. Maybe ill switch to a M1 filter next time.
Zonian22
Nov 14, 2015 01:20 PM
BlueAquarian
Sep 10, 2015 02:18 PM
jfman55
Sep 5, 2015 02:55 PM
Zonian22
Sep 2, 2015 08:19 AM
emsrph
Aug 31, 2015 10:28 AM
