New Acura RDX checklist
Since this is my first new car purchase, I don't know what I need to check on. I heard people check all the functions of the car and the vin#. Should I check the tires for wear or maybe rust on the bottom? Is there a release form you sign after you're satisfied with the checkup?
For a brand new vehicle (assuming from the dealer) you just need to be satisfied that all the features work. Try every switch, accessory, etc. Make sure the seats move properly, fold down, etc. If you discover anything not working properly after you leave, back to the dealer and they'll fix you right up.
clear a whole morning or afternoon for delivery if possible. try to pick the car up on a good weather day. always look for scratches around the body. like canuckle said, try every switch (doors mirrors, windows wipers etc). all the lights, audio, moonroof etc. spend a good hour trying all these things before leaving the dealer. save the hassle of identifying a scratch a few days later at home, at bring it back to the dealer. then they can argue you scratched it etc.
drive it on the highway, make sure the car is in alignment, tires are balanced.....all the more important things that dealers say they have checked and or done but really dont because "its supposed to come from the factory" in alignment, balance, etc etc. Id say those are my most common 2 issues when getting new cars.....its been a reaccuring theme in the last 4. Also....check the tire pressure...some dealers forget to deflate the tires after delivery (they are set at 40+ to avoid dead spots while sitting). make sure they are at your desired level. good luck!
haole kama'a-ina
When you get your manuals, look for the "Maintenance Journal". In the very front is a TQI (Total Quality Inspection) checklist. The dealer performs this before delivery and all items should be checked off. Some dealers have been known to pencil-whip the TQI -- note (on this forum) how many cars have been delivered with 45 psi shipping pressure in the tires.
You can use the TQI guidance to do your own inspection; most of the items are basic. Bring a small flashlight, tire pressure gauge, and the phones you want to pair.
My dealer also put the RDX on a lift so I could do the underbody inspection. (New cars leak too.) If you ask for this, they may raise the car before you get there -- and they will have wiped it nice and clean for your your underbody tour. Take the tour, and identify the engine, transmission, transfer case and rear differential. Have them show you where the driveshaft and axleshafts enter and exit those units. There are oil seals there.
Do your road test (TQI part 9) and have them raise the car again. NOW do your tour and look for evidence of leaks on the items you learned earlier. Pay particular attention to the shaft oil seals. If you spot fresh oil (oil is viscous, has odor, and looks yellow, red or purple on a white paper towel) don't accept the car until you've seen a work order resolving the leak.
Some dealers may cite liability concerns about letting you in the shop, but mine was gracious and very helpful.
In all likelihood any issues found, will be minor dealer oversights. Pair up your phones and enjoy your new sport compact. When you have questions, come to AcuraZine -- these guys are great!
Originally Posted by MMike1981
One thing i have always loved about Acura owners and the brand, the people are smart, they know what they want, and they are there for other reasons than branding and status, hence all the comments that permeate this board about value, resale, std features, reliability, and design cues that are neither offensive or vanilla, but edgy and just right.
I personally don't worry much. Any issues you discover immediately will be fixed. It would be extremely rare to find a rusty, worn tired new car at any dealer.
I found a small hole in my center armrest 4 days into ownership, talked to the dealer and they have a new one on order.
rockyboy
01-25-2016 06:00 PM
