Moonroof open and will not close
Hi RDXers.
2007 RDX
opened the moonroof today, seemed fine. Went to close it and all i get is a single faint click that seems to come from rear of the moon roof ( i think motor ).
each time i push close button, one click. Sounds like motor is getting current but is not turning.
Question: has anyone had this issue... And how did you fix it?
appears per my repair book i have to remove the headliner... which i am really bummed about because it looks to be challenging.
anyone got experience with getting to the motor?
thabks.
Boxster98
2007 RDX
thabks.
Boxster98
Got it to close!
Found a way to tap moonroof motor. RDX 2007
Found access via ceiling light
i REALLY did not want to take apart the headliner, A-frame trim, B-frame, quarter panel, and that other hard stuff. Not to mention it is The weekend and Acura is closed for replacement clips. Instead i tried another approach. I have used the trick to tap on an electronic motor with a hammer.
RDX moonroof motor is toward the rear of the car, just in front of the rear ceiling light. I removed the ceiling light, and unplugged it. Then i got a long screwdriver/punch and felt around inside the slot between the headliner and roof. Once i felt the motor i gave the punch a few bangs with a hammer. Presto. When i pushed the moonroof switch it closed. This is not a permanent fix, but i was able to get it closed!
Boxster98
Boxster98
vietxquangstah
09-27-2017 06:38 PM
jda123
05-22-2011 08:49 PM
dmbfan36_23
08-08-2005 09:24 AM
