engine oil dipstick
engine oil dipstick
this is my first cuv to own, i noticed that the engine oil dipstick is quite long and probably bends at certain parts of the engine as you insert it. my questions are:
a) i am not sure if i can get a proper read yet since it's only been 1k miles and everytime i re-insert to read, oil inevitably gets into the rest of the stick. the engine oil looks really thin/light - havent done any oil change YET as it's still new (1k Miles)
b) does the dipstick really "bend" at some point? it certainly feels that way as it seems to coil in as you insert and pull it out.
c) i havent checked the AT dipstick yet, just wanted to make sure this is really the case - my other cars are that, cars, and the dipstick just goes straight down and, haha, not as long!
d) the manual indicates that you should inspect every time you fill up. really? i used to just check it monthly or once every 2-3 mos for my other cars. wouldnt/doesnt this car have a warning for low engine oil?
thanks.
thanks.
it does bend but you should still be able to get a reading on it. It is a bit of a pain to put back in compared to my other cars, but if you put in slowly (err sounds R rated lol) it goes in fine. Leave the dipstick in for a bit before pulling it out for a recheck.
StayAtHomeDad
You should check the oil periodically because Turbo engines are likely to consume oil. Every fill up may be too much, but you should definitely check it on regular basis.
Carbon Bronze Pearl 2008
thanks.
thanks.
PS. The computer in the RDX will definitely tell you if any fluid levels are low and/or need changing.
StayAtHomeDad
Thin/light looking oil = clean oil. You're good to go. It's best to check the oil after the vehicle has been turned off for a while and on flat pavement so you don't get a "false" low fill reading on the dipstick. Yeah, the dipstick on the RDX has lots of bends and turns, but just do as above and you'll be fine.
Winshield Fluid
In regards to the Windshield fluid, is there a LOGICAL reason that this feature is only available on Canadian models? I find this to be really odd.
Is there any way this can be added to a US model? Does Acura think that Canadians are incapable of monitoring even windshield wiper fluid on their own?
eltightwado,
there is a DIY section for these kinds of questions.
couple things to add. color of engine oil doesnt indicate that an oil change should be in order. Its the wear and tear material inside which is invisible to the naked eye. just stick to a reasonable MID and you'll be fine. Also as for checking dipstick you should do it immediately because oil (specially warm synthetic oil) can climb up the dipstick while inside the crankcase. pull out, wipe, insert, quickly pull out, and check levels. you can get the hood wide open like this to make your life easier. Wish it had the straight dipstick from the TL.
BoricuaTL
04-08-2016 01:08 PM
