Clicking sound after going into drive
Old 03-20-2014, 01:24 AM
3rd Gear
777rvrrr's Avatar
Looking for some input on whether this is normal or not.
Every time I start the car (going to work/leaving work) and go into D, I hear a clicking sound that appears to be coming from the engine area. It happens a few seconds after going into D after reversing out of the garage, as well as a couple seconds after going directly to D.
The other thing that I noticed is that within 10 seconds or so of being in D, it feels like something is letting off the brakes. If I have my foot slightly on the brake pedal, I can feel it adjusting/moving.
Are these things normal?
Thanks for your help.
Old 03-20-2014, 08:13 AM
Tomtwtwtw's Avatar
Just curious, how long has the engine been running, and are you using the a/c? The brake assist uses engine vacuum, so sometimes when the load or rpm of the engine changes (i.e. a/c compressor kicking on, fluctuations during the engine's warm-up cycle) you may feel a slight variation in the pedal feel. Of course, that doesn't explain the clicking...maybe someone more familiar with this car has an answer for that.
Also, possibly a stick parking brake?
Old 03-20-2014, 09:24 AM
Mr Marco's Avatar
*ABS check
Old 03-20-2014, 11:02 PM
dcmodels's Avatar
If the vacuum level has lowered since the last drive, the pump makes some noise. I have hearing loss, and hear nothing but the engine myself - however, you can open the hood, and have someone else start your car, and try to better determine the location of any noises just after startup.
Old 03-21-2014, 02:50 AM
3rd Gear
777rvrrr's Avatar
Thanks for the replies. To answer a couple questions:
It's from a cold start - either in the morning or in the evening when I'm headed to or from work.
The difficult thing about that is the sound only happens when going to D and moving a bit.
Appreciate the help all. Was just wondering if this was normal. Will probably give Acura a call to see if they know.
Old 10-22-2014, 11:48 PM
GLP
3rd Gear
GLP's Avatar
I'm digging up this old thread because have the exact same clicking noise as described in the OP. Mine is a 2010 2WD with 100k miles. Does anyone else have this noise?
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
ibGTV
09-28-2015 03:40 AM
Iain MacLeod
09-17-2015 01:01 PM
sputik
09-07-2015 01:40 PM
Quick Reply: Clicking sound after going into drive
