Car wash for RDX
Car wash for RDX
Hi everyone,
Vehicle: 2008 RDX tech. All stocks.
Last week, I took my RDX in for a regular plain car wash. It was touchless. This RDX is my first turbo vehicle and it has an opening on the engine hood. During the car wash, i realize that water could be getting into the engine via the turbo hood because water from touchless system is very strong. After the car wash, i checked my engine and i found puddle of water in my engine...everywhere. I am not going to use touchless car wash anymore.
Two questions:
1. Do you guys think my turbo/engine is damaged? The engine was off during car wash. There wasnt "a lot" of water that got into the engine, but some did get in. It was wet
2. How do you guys wash your RDX to avoid water getting into the hood?
Thank you everyone. Appreciate your input!!
Two questions:
The following 4 users liked this post by justnspace:
rockstar143 (06-18-2012),
SharksBreath (06-18-2012),
TruckerBomb (07-22-2012),
wrestrepo (06-18-2012)
mrgold35
I take my 08 RDX Tech to the car wash 1-3 times a month with no problems. A touchless car wash can’t compare to a monsoon down pour at 65 mph on the hwy.
I usually wash the engine a few times a year just to get the road dirt off at the You-wash-it-place. I just make sure to remove the plastic turbo intercooler hood and use a home vacuum to suck up any bugs/junk. I never spray the water from the hand wand into the intercooler. I’m a little worried the high pressure will bend the fins if you spray directly. After washing the engine, I drive about 20-30 mins on the hwy to dry everything out. Head back home and check for wet spots under the hood.
You should be A-OK with the touchless car washes. Maybe you can drive the RDX around for 15-20 mins afterwards to dry up any possible water build-up in the engine.
Renzan (06-25-2012)
Renzan - being cautious is also being smart. not asking questions isn't.
you dont have any worries with water being sucked
into the engine and damaging it with any car wash.
the water probably ended up on your top mount intercooler for the turbo. its a closed system and water cant be sucked into the engine there.
your air supply and air filter to the engine are enclosed and watertight and protected near and in the front fender .
Renzan (06-25-2012)
Still, my 2009 RDX owner's manual says on page 355:
"NOTICE: Do not spray water (from such sources as garden hoses, high pressure sprayers) into the engine compartment. It may cause serious damage to your vehicle, and could also damage the intercooler fins."
I do sometimes spray water under the hood, with the hood open, to clean the engine. BUT ... I am very carefull where the water is sprayed, and also I use only a garden hose with very low pressure. That is, I either just use the open end of the hose to flood the area and wash away any cleaner I have used, or if I use a hose screw-on pressure valve I do not use the full force (only open the valve a small amount to create a light spray).
And I am careful not to direct water into any electrical connectors, of which there are many underhood. Or against the intercooler fins. Or any place that has a cap such as the Power Steering cap, engine oil cap, brake master cylinder, etc. In other words, just consider the various parts of the engine that should not get water in it, and do not direct a lot of water there.
I would also use caution with using chassis (bottom of car) washes. There is a lot of wiring underneath, such as for the rear electronically controlled differential. I just use a garden hose, which has much less pressure than a car wash. And I can also control where the water is directed. So I do wash under the car several times per year to remove dirt (summer) and salt (winter). But I do it by hand with a garden hose, not the car wash.
I hope that this is clear and helpful. JMO
andysinnh
09-05-2015 11:38 PM
