Can't select Auto with fresh air
It seems like every time I have the a/c in Auto the recirc light comes on. When I try to turn off the recirc and have cooled fresh air, the auto system goes off. What gives? My other car will gladly do auto with fresh or recirc air.
Everything is automatic after you hit auto. Then things go off automatic one by one as you press buttons. Think of the auto button as a "reset to full automatic" button. So just press auto then press the recirc button to until the light is off--you then have everything automatic except the recirculation.
Shoofin is right, but to add to that....
Raise the temperature because if the set temperature is "significantly" lower than the ambient temperature, it'll try to recirculate to maximize cooling. If you raise your temp up a few degrees (i'm assuming you have it around 70-72), you'll probably find that the recirculation will go off--try setting it to ambient temperature or something comfortable around there...
SidhuSaaB
05-30-2020 12:40 AM
navtool.com
31
11-16-2015 08:30 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
