brake pedal seen to slip/grind when braking and abs sensor light on
Hi i have a 2007 acura rdx and this morning going to work i got the following code attach in the pictures above also my brake pedals seen to slip (grinding noise) mostly every time i slowly brake or completely brake at slow mph mostly happen, Any thoughts will be deeply appreciated ??
How are your tires? When was the last time you replaced your brake pads/rotors and brake fluid..?
When you get a chance...
Google All-Wheel drive:77
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=all-wheel%20drive%3A%2077
https://acurazine.com/forums/1g-rdx-...nction-682423/
Maybe try a hard reset by pulling the + battery cable off for 10 mins
pvtplum1290 (10-03-2016)
