B1 Service - what's it entail? cost?
Silver/Ebony/Tech
Just got my B1 service notice showing up in my MID. What's usually involved, how much does it cost and what advice do you have?
Thx!
Thx!
2007 RDX CGP/Taupe
Whether or not your first oil change is free depends on what you negotiated with your dealer. I've heard mentioned some receive a few free oil changes and some pre-pay for theirs at the time of purchase. Below is a breakdown of what the "letter" and "number" mean on your maintenance minder.
I hit my first oil change at 4,500 miles and the maintenance minder only stated "A". I'm at 9,000 miles and my maint. minder is at 15% and it is calling for a "B1" service.
A Replace just the engine oil.
B Replace the engine oil and the oil filter, rotate
the tires, inspect the front and rear brakes,
check the parking brake adjustment, and
inspect several other items listed in the O/M.
1 Rotate the tires.
2 Replace the air cleaner element, check the
drive belt, and replace the dust and pollen
filter.
3 Replace the transmission fluid and transfer
fluid (if equipped).
4 Replace the spark plugs, replace the timing
belt (if equipped), inspect the water pump,
and inspect valve clearance.
5 Replace the engine coolant.
6 Replace the rear differential fluid
1 Rotate the tires.
filter.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
