AC doesn't work when hot
Old 09-22-2015, 10:58 AM
5th Gear
Kres43's Avatar
My AC wouldn't work when it was 98 or hotter outside. After research and calling ACURA, it sounded like it was either relay or coil/clutch. We tested the relay and it appears not to be the problem. My brother is a mechanic at Mazda and replaced the coil/clutch compressor. Now, it doesn't work when it was 88 outside And blows hot air. The entire rest of the system tested fine and freon level was great. However- it's now worse than it was!! What else could be the issue?
Old 09-24-2015, 08:39 AM
Ayu688's Avatar
Had the same issue. Replaced the relay but no luck. Didn't go as far as coil/clutch compressor. Took it into my mechanic and they saw an obvious leak coming from the condensor. Replaced and recharged and now works well.
Old 09-24-2015, 09:57 AM
5th Gear
Kres43's Avatar
I believe they checked for leaks and nothing - the change in freon taken out and put back in was super minimal- not even with a mention.
Old 10-03-2015, 07:16 PM
russianDude's Avatar
I was battling the same issue, relay replaced, but did not help.
Finally, dealer replaced A/C clutch coils (expensive, $700), and it works great.
If its not relay, its a clutch coils on compressor, they are common cause for this problem.
AndrewS
19
03-14-2024 06:59 PM
Powder Monkey
2G CL Problems & Fixes
09-09-2018 12:55 AM
01CLOwner
10-09-2015 01:07 PM
acurajj
09-19-2015 03:47 PM
dlknight
09-03-2015 07:54 PM
Quick Reply: AC doesn't work when hot
