2010 acura rdx radio work but no sound
Old 08-19-2017, 07:36 PM
Tilman121w's Avatar
My 2010 acura rdx my radio work but no sound on the spakers. I check all the fuses all are fine and also replaced radio and amplifier but still no sound . Now I don't know what to do.? That's any one had that issue like me .pleade help asap
Old 11-27-2017, 08:30 PM
Kevin125's Avatar
I would say check the amp. It is located behind the radio. Remove the radio and get a voltage meter and test to see if you have power. That's the only suggestion I can think of because if the radio turns on then you should At least hear from one speaker. If all speakers don't work then it might be the amp
Old 02-12-2018, 05:57 PM
Lc46em's Avatar
This may sounds stupid but did you put in the radio code from the factory ?? If you changed all that stuff out you may have not entered the correct code which will cause your issues
