2007 RDX Starting Issues
Old Nov 13, 2019 | 08:38 AM
Cody Cochran's Avatar
Hey all,
I have an '07 RDX with the technology package that is having a cold start issue. It's been going on about 3 years total but only when winter hits and the temperatures get to be about 30°F or below. The car cranks, but too slow to start. Immediately after I put another source of power on the battery it will fire right up. My local Acura shop has checked it out and they said it would be good to go, they disconnected the hands free unit. I have replaced the battery a total of 4 times, I had the starter rebuilt and replaced the terminals for the battery. I have checked over the last couple years and it has not been losing voltage when it was not running. Any information would be appreciated greatly.
Old Nov 13, 2019 | 11:21 AM
Tomtwtwtw's Avatar
Not sure what specific battery you're using, but you may consider getting something with a slightly higher CCA rating. I want to say the actual OEM battery from Honda is near 500, but the replacements I get from Costco are rated at 640. It does crank a little slower at or below freezing, but always plenty of juice to get the car running. We use a group 35 battery, but the actual CCA ratings within that size group range from under 500 to over 700.
Cody Cochran
1G RDX Problems & Fixes
Nov 13, 2019 04:10 PM
kenwaldner
21
Aug 13, 2018 09:00 PM
DWONG415
1G RDX (2007-2012)
Apr 26, 2016 09:01 AM
Koreets.RU
May 18, 2015 05:20 PM
Animagix
Apr 6, 2007 08:48 PM
