2007 Climate Control Damper Groaning
I am experiencing issues with the the climate control on our 07 RDX. The issue is when adjusting the temperature, there is a groaning (in what I assume is the climate control damper) under the steering wheel. The issues is also heard in auto mode when it is adjusting the temperature. I did a quick search but I have not seen any solutions to the problem.
Any ideas? Thanks in advance.
Found the solution is a previous post.
Thanks,
FYI, here is the link.
https://acurazine.com/forums/1g-rdx-diy-faq-161/diy-%96-fix-driver-side-hvac-mix-door-noise-862172/
Thanks,
I think dealer can lube that with the same stuff they use on the doors.
MrHeeltoe
20
02-23-2023 01:54 PM
MetalGearTypeS
08-29-2016 08:28 PM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
