19" Acura Wheel Options
Old 02-09-2024, 12:48 AM
braxus's Avatar
I'm wondering what Acura wheel options would be a correct fit for my 2007 RDX? What year and models should I look for? Also should I stick with the 235 tire size for 19" or can I move up to 245?
Old 02-09-2024, 09:24 AM
Tomtwtwtw's Avatar
I recommend you search through the tires and wheels category in this forum - I'm sure these questions have been discussed before and most like the info is there on bolt pattern, offset, etc, as well as good tire size options for different wheels.
Old 02-09-2024, 01:58 PM
DaIll1's Avatar
I use the wheels from my (past tense) 2016 ILX as my winter wheels. Same size and offset. When on the ILX I ran a 245 Pilot Sport.
Old 02-09-2024, 10:39 PM
braxus's Avatar
I did do a search and there isn't a lot of threads mentioning the options for 19" wheels that can be used on my 2007 RDX. Only one mentioned a 2019 RDX, but it didnt get into specifics. No one mentioned any other Acuras that will swap on either. 19" isn't mentioned much.
Old 02-10-2024, 08:36 AM
mrgold35
mrgold35's Avatar
Received 1,532 Likes on 1,193 Posts
What I find helpful is looking at aftermarket rims on Tire Rack or Discount Tires for your vehicle. You can narrow down the specs if you want to upsize to 19" rims and get the common size, width, offset, bore size, bolt pattern, etc... that will work for the RDX. There was a 19" rim option for the 1st Gen RDX. You could search eBay for 2007 RDX 19" rim and you should get a few matches. The eBay description should list the OEM wheel specs and be very close to what you find on Discount Tires and Tire Rack. The Offset will be different if you decide to go with narrower or wider aftermarket rim compared to the standard OEM 8" rim width.
rdxjockey
1G RDX Tires, Wheels & Suspension
26
04-25-2023 11:59 AM
RRK0818
09-30-2020 01:32 PM
googlefish
04-14-2020 08:04 AM
silvrbreez
10-26-2013 08:45 AM
Quick Reply: 19" Acura Wheel Options
