Stock Wheel Specs
Whats up with RDX owners?
Stock Wheel Specs
Hey guys, Ive searced around trying to find the specs of the wheels off a newer model NSX but I havent had any luck. Im looking for the 17" wheel specs. Id like to know the offset and the width.
And Id also like to know if a big brake kit can fit behind them. IIRC the 05 models had 11.7" rotors, so Im trying to figure out if a 12.6" rotor and 4 piston caliper will fit.
Thankyou in advance.
I was able to locate widths on Wheel Collision Center, but still no offsets.
If anyone can supply that info it will be greatly appreciated
Someone correct me if Im wrong, but the front wheels are in the 40-50mm offset range, no?
2002 - 2005 Front 17" 7" 17.35 lbs. 2002 - 2005 Rear 17" 9" 20.0 lbs. I believe 2002-2005 front wheels are 17x7 with a 55mm offset and the rears are 17x9 with a 56 mm offset. HTH!
Wow thread revival. Thanks for the info!
that's a pretty high offset. you wonder what sort of spec difference it would have made to have much wider tires that even "sporty" cars are running today on the NSX. like a 245/275 setup would probably have made a massive difference on all the numbers it put up.
