used springs
nippon_wa 2.0
Originally Posted by wakeboardfusion
legendary, i think im goin to seattle around march to may, we should have another meet
let's make one..
p.s: i also bought my teins in used condition.. and it works great.. and i sold my neuspeed springs which is like 4 yrs used to legendaryCL98... :P
I'm a llama :(
Originally Posted by jtothees
You will eventually need a camber kit with any springs to prevent negative camber..
AWD Torque Monster
Originally Posted by Motohip
That's not true, an alignment will take care of a mild drop without the need for a camber kit.
moto there is no camber adj to correct alignment on the front suspension. at least on my 97 there isn't. helm says if camber is off something in your suspension is damaged. no possible adj.
prokits seem to give almost a 2" drop especially if they are already settled from being used. u will def need a camber kit. i had 2.25" drop on mine, but i did have my konis set on the lower perch.
and defintely buy those springs. nothin better then a good deal.
Get a camber kit with any springs you purchase, regardless if its a mild drop or not...you will save money on tires....promise
I'm a llama :(
I got my Pro Kit used from CLPower a long time ago. I've had no problems with them whatsoever. I have also never needed a camber kit and have never had to replace my tires yet.
So, yes you can buy them used with no problems. I think $60 bucks is a good price and you shouldn't need a camber kit for the Pro Kit. The drop is only 1 to 1 1/2 inches.
AWD Torque Monster
With my other Honda I was dropped about 2.5 inches and I was within the limits after I got my alignment.
I'm a llama :(
were you on oem tire/wheel setup? thats when the car is really slammed. it also depends on the tire. my oems barely wore uneven, but once i had winter tires way diff story and again if i would have left the camber as it was it would have ate up my soft summer tires also.
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
