Tie Rods questions
1999 Acura CL 2.3
Tie Rods questions
Hello
ok..my mechanic came over today to check out this sound ive been having when making right turns in a 45 degree angle.
he said i need new inner tie rod for the left side but might as well change the right too and at the same time change the outer ones..i took a quick look in my phone for description of what it is and i said beck and arnley and moog popped up and he said go with moog..
im looking at rockauto for them for my car and i see moog only lists "front inner"...
is there a left or right inner???or is it just called the inner???
and im assuming i need 2 of them for each side right?
thanx all
thanx all
I have a 3.0 so could be different but I believe you just need 2 inners and 2 outers total. I don't believe there is right or left on the inners so you would just order 2 inners ( 1 for each side) and the outers I believe left and right matters so get 1 left and 1 right. As always, you'll definately need an alignment.
1999 Acura CL 2.3
ok..thanx for info mate...
im also considering getting new brake pads for the front while im at it...the 2 front tires were put in less than 6 moths ago so might as well get everything dun so i dont have to remove any tires anytime soon..
p.s..is it reccomended to get new ball joints while im at it??and if so i would need 2 right??
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
navtool.com
31
11-16-2015 08:30 PM
lanechanger
10-13-2015 10:56 AM
navtool.com
09-25-2015 05:15 PM
