Alignment Specs
Alignment Specs
After putting on AGX struts and Pro-kit springs, I took my car into Firestone to get it aligned. I mentioned to them what I did and was worried whether the camber would be out of spec or not. Well, no need to worry as the camber was well within spec. I remember seeing a lot of posting on CL's with Pro-kit springs which needed camber kits--don't know why, as the camber specs are pretty wide on the CL. Here's the spec info (in degrees):
Front:
Camber -2.0 to 0.2
Caster -2.0 to 6.8
Toe -0.16 to 0
Rear:
Camber -1.7 to -1.0
Toe -.16 to .16
The only thing that was out of spec on my car was the toe, which they fixed. My front camber started out at -0.9 degrees. After the Pro-kit, my worst camber was on the front right (-1.5)--which is with a 1.5" drop, so I'm thinking that my CL could be dropped nearly 3" before having to worry about camber being out of spec. Does this sound right?
Front:
Camber -2.0 to 0.2
Caster -2.0 to 6.8
Toe -0.16 to 0
Rear:
Camber -1.7 to -1.0
Toe -.16 to .16
...if I had the money.
What year CL do you have? My '97 service manual says:
front
camber: .12 +/- 1 degree (-0.88 to 1.12)
caster: 3.3 +/- 1 degree (2.3 to 4.3)
toe: 0 +/- 2mm
rear
camber: -1.2 +/- 0.5 degree (-0.8 to -1.7)
toe (in): 2 +/- 2mm
those specs you put up look pretty extreme. i would double check with Acura if i were you...
front
toe: 0 +/- 2mm
rear
toe (in): 2 +/- 2mm
emailnatec
29
09-28-2018 04:27 PM
4drviper
09-23-2015 07:42 PM
