Won't start tried every thing
I have 99 2.3 co Manual I have just replaced a dead battery ignitionswitch and fuel pump checkedall fuse it cranks but will not start no spark I have power every were but at the disributer power to ignition switch out of switch to the starter in the fuse panel and out of the fuse box I am stuck imbolizer light blinks and goes off like normal and no codes thrown any seen this before
Same no start
I have a 97 acura cl 2.2 auto. Replaced fuel pump, main relay, ignition coil, spark plugs and wires, new starter and battery as of 2017. No spark, gets fuel replaced TPS and MAP. I'm at a loss next is timing belt and water pump.
Does it crank?
Same 97 cl 2.2. Replaced fuel pump, Main relay, TPS, MAP, spark wires, ngk spark plug correctly gapped, ignition coil, new starter new battery.
Tested all fuses and links have continuity through circuits.
I have a new timing belt and water pump kit will be the next replacement. Still no start to date. Is there a way to brace crankshaft without Honda pulley tool? All labor and replacements done by myself. Please help. Its been 3 months.
It turns over and crnks but no start no spark
I'm new to the site and wasn't aware of live feed apologies
I'm starting to think it's either in limp mode or jumped time I don't know
No spark meaning you've pulled the spark plug and when cranking, you don't see a spark?
Yes I've tried doing the plug test to ground and nothing. I've tried starter spray or a carbon cleaner in TB and it won't do anything to start. I have videos but don't know how to post them I understand it's hard to diagnose without being here based off of what I say. But it's driving me nuts
Besides what I've said was replaced it's sitting at 273,000 miles and I don't think the timing belts ever been replaced I have said kit to do so.
My concern is when it died I was coming to a lright mind you it's an auto it went from regular rpms and just dropped to zero no loud noise no back fire it just died like a manual stalls.
