rough idol in cl 3.0 HELP
Old Dec 20, 2008 | 08:24 PM
sholmz's Avatar
3rd Gear
I thought I posted this earlier, but can't find it. So maybe I didn't hit the post link.
Any my 1998 Acura CL 3.0 has not been started up for about 6 weeks until today. I started it and it would shake the entire car it was running so bad. Like a very low idle. It also sometime will serge, up an down. I took it by Advanced auto and they put the machine on it and said it needed a very expensive idle sensor. Does this sound correct? If so how did this thing go bad sitting in the yard. Thanks for a rapid response.
Old Dec 22, 2008 | 04:52 PM
*BAY*CL's Avatar
worki o w projct..
if the idle is bouncing up and down and acting up than it could be that you need to clean the iac valve.. there's a few threads about this problem just search you'll come across some info
Old Jan 6, 2009 | 10:15 AM
I am Hydrogen's Avatar
5th Gear
You might also want to take a look at your engine mounts. I have a bad vibration at idle and a support arm on my front mount is completely cracked. Here is an explanation:
https://acurazine.com/forums/1g-cl-problems-fixes-71/how-fix-2-2-2-3-vibration-idle-689195/
baelim
May 10, 2018 09:53 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
ceb
ILX
Sep 27, 2015 10:56 AM
IlliniAcura
Sep 19, 2015 09:31 PM
