Rotors
Rotors
Im not very good at writing these things but I will try my best. Im trying to replace my front rotors and there not like normal ones. There are 2 pieces. When I took all the bolts off the inner circle of the rotor. There where barrings in there. Do I take all of that out. im so confused and do naht want to cause more damage ...any help is welcome
It helps to put as much info about your car as possible. Is your cl a 97? if it is you have the hub over rotor design which means you have to have your hubs pressed on/off to remove the rotors. If its a 98-99 it should be as simple as removing the caliper and removing the two rotor retaining screws(if they are still intact).
hey sorry for not having the year. Not very good at these things ...but my brother and I figured it out without a press machine lol. It saved me like what 500$ or so...Thanks for the info
Be careful not to damaged the wheel bearing if u choose use the press/unpress install. There is a 2nd way of changing the rotor without using any press. It takes longer and there is no risk in damaging the bearing. U have to take the whole knuckle off the car, there is 4 bolts holding the wheel bearing/hub assembly to the knuckle!
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
