Please Help - Electrical Draw
Hi,
Please HElp!! I posted this same question about 4 days ago and I have not receive one reply!
I have a constant 11.84 draw on my battery when my car is just sitting and not running. All the fuses were pulled and measured with a fluke a meter to measure for a drop in volts when the (unknown culprit) ir fuse was found.
However after checking all three fuse boxes it consistently drew from the battery with the measurements from 11.82 - 12.25. Even the wire from the alternator was pulled with no drop in measurement. Does anybody know what I should do next?
It doesn't start. 95 % of the time I have to get it jump started. He measured it using a jumper wire and a fluke multimeter connected to the battery and negative cable. After he got the measurement for the contineous draw. he proceeded to pull every fuse looking for a drop in the reading to determine where the short was. He did this twice by himself once and with another tech the second time. They tested the altenator as well and was unable to determine where the draw was coming from.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
joflewbyu2
10-08-2015 11:16 AM
