No Dash Lights, Tail lights or Parking lights
I hope someone can help me out?
I brought the car to the dealer and after $378.43 for parts and labor they can't fix my problem. I had them installe a new light switch (driver side) and a lighting power relay (under hood), they changed every lighting fuse (under driver side). Pulled every exterior light out one by one and I still have no tail, dash or parking lights. Is anyone here smarter than the Jackasses Acura Dealer Technicians? |
There is a taillight relay that coincidentally enables front parking lights, tail lights, license plate lights, and dash lights. It is driven by fuse 2 a 15A fuse. Tail light relay is in the under hood fuse box. It should be located on the box lid.
Above is based on a 2.5TL manual. Yours should be similar, perhaps identical. good luck |
where is the rear light relay located? I see a 'lighting relay' next to 'dimmer relay' under hood fuse box, is this it?
Following
Originally Posted by annielaurie
(Post 16203181)
Originally Posted by Jairo Espino
(Post 16692212)
I’m having the same issue with my 2001 cl type s Automatic I’ve checked all my fuses and they are all good please need help 🙏🙏
| All times are GMT -5. The time now is 11:44 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
