NGK Iridium Spark Plugs VS Platinum Plugs
Hi
I have 99 Acura Cl v6, 98xxx on it
Right now I have NGK Iridium IX spark plugs in my car with NGK Wires
I was talking to my repair guy about Spark Plugs & he said that if I change back to PLATINUM Plugs I can improve my MPG by 2 -3 miles ( right now I am using only CHEVRON regular gas. & I get about 17-18 MPG)
he told me IRIDIUM Sparks gives out bigger spark & hence it use more GAS, by going back to Platinum it gives small Spark & uses less gas ( NGK Platinum is OEM for Acura CL. NGK # PZFR5F-11, Acura Part # 4363)
What you guys think about his theory? Is he correct about it?
Should I go back to NGK PLATINUM to improve my Gas Mileage?
Thanks guys
Thanks guys
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
I dunno about the difference in gas mileage, but I get great gas mileage with my NGK Iridium, but i think they do put out a bigger spark. Try it why not
They shouldn't reduce the gas millage. A bigger, hotter spark will burn more of the fuel in the combustion chamber. The amount of fuel injected into the combustion chamber is not related to the size of the spark. By that I mean, no matter what size the spark is the same amount of fuel will be introduced into the combustion chamber. It seems logical to me that a bigger, hotter spark would burn more of the fuel and therefore make your engine more efficient and increase your gas millage.
what you say make sense
i guess i will not change Plugs
thanks
i agree with tron. also, the magazine "DSport" just did an article on the differences of the various spark plug materials and which are best for certain applications, etc. you might want to look it up there, as i didn't read the article with too much interest, as they also did a clutch buyers guide in the same magazine. hopefully that helps, but i would stay with the iridiums.
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
