keyless remote chirp works intermittently
hey guys, i need your expertise. i have a 1998 acura 3.0 cl and i'm having an issue with the siren. i have it set on "chirp," but it only makes the sound sometimes when i lock or unlock it and the times it does work, it sounds really faded and low. the lock and unlock works fine, horn works too. the panic button works also, but when pressed, the lights blink and all, but there is absolutely no sound...any ideas?
Have you replaced battery in remote? Cause I think that might solve my problem too.
I had the EXACT same problem and it went away after changing the car battery. Might want to recharge your car battery and see if that chirp is back to normal.
