Help please
Help please
hey guys installed a stage 2 clutch and flywheel abotu 2 weeks ago and been babying the car today i decided to do a little pull nothing hard to feel the diffrence. This is what happend when i wen first sendond at about 3k then i tried shifting at about 4500 and when i depressed the clutch the rpms shot up to about 5500 and droped. Can my gas peddal be getting stuck ? or somthing with my MAP sensor i think its messed up. Help anyone ? i cant figure it out
Sounds like it could be your MAP or TPS sensor. Did you do the clutch yourself? Are you sure all the connections are good? If so I'd start with those 2 sensors and work from there.
if i am correnct its the IAC sensor the wires are messed up in the H22 set up i cleaned it up and pushed the connectors and the car runs beautyfull right now =) can wait to give it a nice ass ripping once the clutch is broken in
