AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   1G CL Problems & Fixes (https://acurazine.com/forums/1g-cl-problems-fixes-71/)
-   -   engine swap!!!!! (https://acurazine.com/forums/1g-cl-problems-fixes-71/engine-swap-771785/)
TexasTony6777 Apr 12, 2010 03:12 AM
engine swap!!!!!
I have a '97 2.2cl with a stock motor and auto-trans. Looking to swap out to a Prelude 2.2L DOHC VTEC with 5sp manual trans. I know I need all the extras to install, such as cluth master, shifter, ecu, and motor mounts. Do I need to cut anything?
97BlackAckCL Apr 12, 2010 08:15 AM
You should not need to cut anything, the h22 will use the same mounts, wiring will be your main issue
f22vtec Apr 12, 2010 12:01 PM
pics?
DaInFaMMuS1 Apr 12, 2010 10:51 PM
Do a SEARCH. It's been covered numerous times. U can use your stock harness, and it bolts right in, no banging on the engine bay unless you have a Skunk2 intake manifold or a supercharger.
As for the tranny swap, thats gonna require some cutting/fabbing for the 3rd pedal and clutch master/slave and linkages probably.
© 2026 MH Sub I, LLC dba Internet Brands
