clutch problems 97 acura cl
Old Jun 21, 2015 | 05:20 PM
toranddet0's Avatar
6th Gear
So the other day i was driving around, and as i shift into third the clutch lost all pressure and stuck to the floor. Got out, checked the fluid, its fine. So at this point im clueless as to what went wrong, because i had tons of bite before it went, doubt i broke the clutch itself. And im not leaking any fluid so it wouldnt be the slave. But thats as far as my knowledge goes. Need some help
Old Jun 21, 2015 | 05:28 PM
Aman's Avatar
Your Friendly Canadian
It could still be the slave or the master cylinder. The clutch master cylinder failed on my car recently. No visible leaking, or drop in the level at the reservoir. I guess the seals inside had failed.
Old Jun 21, 2015 | 05:33 PM
toranddet0's Avatar
6th Gear
thanks! Ive never been good with transmission problems. Im hoping its either of those and not the throw out bearing or something a little more hard to fix.
Old Jun 22, 2015 | 11:40 PM
musiclevelz5's Avatar
If you have no air in the clutch system and have the proper level in the clutch reservoir, then the only other possible issues are the master or slave. I recommend replacing both at the same time that way you only have to bleed the system once. There should be a diy around for replacing either cylinder. Hope you fix it!
Old Jun 23, 2015 | 07:39 AM
toranddet0's Avatar
6th Gear
I just picked up a slave and master, as soon as im off work im gonna see if i cant put these in.
Zonian22
Nov 14, 2015 01:20 PM
Mike Bertram
Sep 10, 2015 09:27 AM
heyitsvic
Sep 4, 2015 09:38 AM
NSolace
Sep 3, 2015 08:02 PM
