Crank fuel pump pumping spark no start
Old 01-17-2018, 04:19 PM
5th Gear
Marc Majlaton's Avatar
Just rebuilt BAXA put it back in went to start it and it ran for 3 sec and cut off. Tried again same thing. Third time just cranks. Checked timing it's perfect.have spark. Fuel pump is running. Did I not plug something back in???
Old 01-19-2018, 12:44 AM
5th Gear
Thx for all the suggestions
I'll elaborate a bit. Drove car into garage removed and rebuilt the 4 speed. Put it back and now it cranks and blows air from the throttle body. I did compression test and got 150 on all 4. It's got spark. Fuel pump is running but I tried some starter fluid anyway. Still no start. I checked timing and it's dead on. I'm at a loss. Please help.
Old 01-19-2018, 05:16 AM
teh CL's Avatar
Check your engine grounds.
Old 01-21-2018, 01:28 AM
5th Gear
About to throw in towel
Checked grounds there solid. Is there a chance the spark is weak? How do I measure that? Why is it blowing out the throttle body? I'm afraid to swap the engine cuz it seems good.
at a loss
Old 01-22-2018, 02:34 AM
5th Gear
Noticed the timing belt is a bit stretched not stupid but has some play. The timing still sits dead on. Could it be burned intake valve?
adam83
04-21-2020 05:21 PM
01cl_blk
07-09-2015 10:41 AM
SENATOR
1G TSX Problems & Fixes
08-15-2012 07:43 PM
01RedCLS
10-17-2009 09:40 AM
StonedCL
09-03-2009 06:46 PM
Quick Reply: Crank fuel pump pumping spark no start
