ABS question?
ABS question?
I am having trouble with the abs light and getting it to flash the codes. I did it with no problem about 5 years. I found the 2 wire blue connector mounted in a blue dummy holder under the glove box. I shorted this connector and turned the ignition on and the abs light stayed on solid and did not flash. This is the right connector right? Anyone with any ideas?
ABS should come on for 2 secs and then turn off before flashing any codes. For some codes, the ABS light may stay on for up to 40 secs when the controller is checking for pump overrun (pump would be buzzing while ABS is on).
I would reset the ABS controller by pulling BackUp fuse for 15 secs and then try again.
good luck
good luck
navtool.com
31
Nov 16, 2015 08:30 PM
lanechanger
Oct 13, 2015 10:56 AM
navtool.com
Sep 25, 2015 05:15 PM
