'99 Acura CL 3.0 Auto - Noise and Vibration only when turning right PLZ HELP ASAP!
8th Gear
Howdy.
My car only makes the noise when turning right and especially when I accelerate(coming from left front). Some would think that this is obviously a CV boot/axle or wheel bearing issue, however we checked the CV boots/axles and they are fine. Also we actually replaced the left front wheel bearing but the problem didn't go away! We even took the car to a reputable car mechanic and he said it was the left wheel bearing....so we're stuck.
Btw, the car has 79k miles on it. I know that these cars are prone to tranny problems and I'm hoping it isn't it!
Help!
Help!
Burn you with a 2.2
check the stabilizer linkage .. on my 2.2 the rubber bushings were cracked pretty bad and a couple were actually missing so that caused some noise and vibration when i turned.
that is what i can think of. good luck.
the balljoints are known to go bad on these cars. is it making the noise whan turning slightly to the left or like a u turn style turn. if its a u turn style then it could be your tire hitting the plastic fender guard.
8th Gear
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
