AC and PSI ?
Old 06-06-2010, 10:05 PM
john6699's Avatar
AC and PSI ?
I have a 98 CL 3.0 air is cold, gauge is at 25 PSI
What should the PSI be at for Coldest AC
I live in FL so it is hot
Old 06-06-2010, 11:47 PM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,130 Likes on 4,801 Posts
You need the first gen side.
Old 06-07-2010, 05:58 AM
Sundance Gold in
celynka's Avatar
Static pressure for the Ac should be 70psi and may be higher depending on outside temp. Operating pressure 25-35 on low and 200-300 on high, but perfect amount of refrigerant in the system can not be determined by mesuring pressures . Its done by weighing during fillup. Being slightly off with ref. wont change anything as most of the gas sits in receiver/dryer that works as sort of buffer
Froid
09-27-2015 06:16 PM
Robospinner
22
09-24-2015 08:47 AM
NBP_BALLER
09-23-2015 08:18 PM
CostcoFanAUS
09-18-2015 06:05 AM
cacheflowe
09-14-2015 10:35 AM
Quick Reply: AC and PSI ?
