My carputer system
Old 04-04-2006, 10:06 PM
  #41
97 Midnite Blu TL
pimpstaman90's Avatar
what is the usb volume control look like and where could I get it
Old 04-05-2006, 11:52 AM
  #42
elserpien's Avatar
you have 2 main options, the griffin powermate which is fairly large, or the phidget sensor encoder that I have that is small but requires some work to make it install it and have it look good. You can find the powermate anywere, and the encoder is here: http://www.phidgetsusa.com/cat/viewp...4100&SKU=1052a
Old 04-05-2006, 01:30 PM
  #43
how handsome I am
agranado's Avatar
Pimped se' freaking auto! amazing job with that.
Old 04-22-2006, 11:32 PM
  #44
7th Gear
snatchbak's Avatar
i like the interior. very custom. where did you get the shift knob.
Old 04-23-2006, 12:39 AM
  #45
stylo17's Avatar
he said ebay
Old 05-17-2006, 09:32 PM
  #46
6th Gear
Drcrono's Avatar
Fuckin Legit!
Old 05-25-2006, 02:42 AM
  #47
ninjaturtle420's Avatar
Old 05-27-2006, 02:45 PM
  #48
My other car is a DSM
TurboMike's Avatar
Great job man, I hope mine comes out as good as yours!
Im about to do this system... i have the same motherboard, 512mb,
and my stock xbox hard drive (10 gigs, and a little slimmer than normal 3.5).
I have not bought the screen yet though, cause i was wondering if the 8" Lillput
would work in this type of setup. When you molded your screen to the dash trim,
did you retain the factory clips that secure it to the dash? do you have pictures
of the build? possibly the back of the trim after the screen was molded in?
Old 05-27-2006, 06:05 PM
  #49
Bent = #1
hornyleprechaun's Avatar
^^ i'm about to mold the 7" lilliput and unless you want to keep the stock trim i am pretty positive the 8" won't fit.. i'll try to take some pictures of what I have now and post them up tonight.. just in case send me a message so i remember
Old 05-28-2006, 03:42 AM
  #50
elserpien's Avatar
Yea like hornyleprechaun said the 7" is a tight fit as it is, you have to cut the trim panel to fit it, but I did keep the stock clips. The dimensions of the 7" are 18.7 x 12.5 x 3.3 cm and the 8" is 20.5 x 16.3 x 4.0 cm. So it probably is possible but might require a lot more cutting/forming and losing the stock clips.
Old 05-28-2006, 03:56 AM
  #51
Slooo97CL's Avatar
really tight set up
Old 05-28-2006, 06:34 PM
  #52
TurboMike's Avatar
is it necessary to retain the buttons that come on the Lilliput? Once its all set up, do you need to still be able to adjust the brightness or anything else associated with the screen buttons?
EDIT: also, as far as the audio output... i have read that you need a line driver to up the voltage output to the amps... are you using one?
Old 05-28-2006, 09:53 PM
  #53
Bent = #1
turbomike pm sent
Old 06-02-2006, 02:05 PM
  #54
Bagel Bomber
Mach30SiR's Avatar
Back up top, just wondering how you sync this with your home computer to update music/files and windows updates? Also does it power up and power down like a computer when your car starts up ect..
Old 06-05-2006, 04:54 PM
  #55
elserpien's Avatar
It has a wifi card built in that connects to my wireless router inside my house, from there I can access the internet at high speed for updates and putting music onto the car's hard drive. I have a Opus power supply that is designed for the the sole purpose of a computer in a car environment, so it soft shutsdown/boots it up with the turn of the key. I also use hibernation mode to speed up the boot up.
Old 06-05-2006, 05:36 PM
  #56
Bagel Bomber
Mach30SiR's Avatar
Thats some sick shit, i'm going to seriously consider this, i will prolly pick your brain about it later. thanks for the reply.
Old 06-05-2006, 05:42 PM
  #57
contrarian in fashion
PimpCL23's Avatar
whoa!
Old 06-08-2006, 03:38 PM
  #58
TurboMike's Avatar
go to mp3car.com for serious info. everything you want to know is there, along with a store to get everything youll need. I have my setup running on my desk right now
Old 06-09-2006, 12:28 AM
  #59
east to west
eeerok's Avatar
Exclamation
thiz joint iz spocka lock hot diggity damn!!
MrHeeltoe
20
02-23-2023 01:54 PM
tsx_boy
12-13-2019 08:33 PM
copmagnet82
4G TL Problems & Fixes
06-29-2016 08:09 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: My carputer system
