Tranny Cooler Install
#42
user & abuser
yah, no pics and bad explination, "facing the front of the car"...??? from where inthe car , on the ground in front of the car, "left side rad"... from standing infront looking into engine bay or from in car seat facing "FRONT OF CAR"?????????????
#46
(assuming you have the hood open and standing in front of the car looking down into the engine bay) you mount the tranny cooler on the front right side of the radiator...towards the middle/bottom of it on the right (drivers) side. When you mount the cooler, you will have to reposition the horn(s)...as they are partially in the way and also mounted on the front of the radiator.
What I did was simply 'swing' the right horn downwards...and spliced the wires with speaker wire and made it so the harness was long enough to plug back in.
It's pretty self explanitory when you look at it...you don't need instructions.
#47
the reason why i was asking is because i did this mod today and i didnt see ant lines from the trans to the radiator unless you were talking about the instructions in the box....they showed the trany to rad lines but the only hard line i had was the one from the back of the trans to the trans filter. so what i did was cut the hard line then unbolted the front half of the hard line to the filter so i could flip it so it would face the front of the car then i just ran some tubing and mounted the cooler.
#48
Got my Hayden Heavy duty would like to do this mod.. any pics please..??
And does it matter which side of the cooler the lines go into? also should the lines be facing up sideways down?
