front wheel bearing r/r
8th Gear
hey guys newbie to the group here but i have a pretty decent knowledge of automotive know how. i have a 97 CL that my in laws bought brand new and handed down to my wife so when i married her i sort of inherited it. its been a great car but its starting to show its age and the brakes started squeaking so i thought id do a quick front end brake job yesterday. Got a cheap set of rotors and pads from oreilly and planned out two hours in my day yesterday. little did i know what i was getting into. So after buying a $20 36mm socket to remove the axle nut i figured out i had to remove the knuckle. 30 mins and a can of penetrating lube later i got the knuckle off only to find figure out i had to press the assembly apart. after an hour of banging with a mallet and a pickle fork i got it apart. I checked the bearings and they didnt look good so i want to replace them but all the parts shops were closed so i changed the rotors and pads and buttoned it back together. My question is how spendy are bearings? and do i absolutely need to have them pressed in an out? Also i saw something about a rotor over hub conversion but after searching i found nothing. Thanks for any help you can provide and i look forward to posting more in the future.
8th Gear
well guys the tips on changing brakes helped me greatly. i used the tip of setting rotor on blocks and pounding the bolts from the back side to seperate the rotor/hub assembly and also used a large socket to pound it out as well. Also gives me hope that i can replace the entire hub/bearing assembly if i need to in the future.
bearings at honda are about $96, since i work for hondai usually get em for like $50. ive replaced 4 bearings in under a year.
https://acurazine.com/forums/1g-cl-1997-1999-56/rotor-over-hub-kits-716813/
nuldabz
09-03-2015 05:49 PM
