Consumes more coolant than gasoline
4th Gear
This ones got me baffled. My '99 CL 2.3 blew a head gasket; so I thought. I removed the head and there was an obvious breach of the head gasket between an oil passage and a coolant passage.
So I had the head surfaced and replaced the gasket. The block was in spec.
But she's still drinking heavily.
I have pressure tested the system hot and cold. When hot I lose about 1/2lb. psi over 20 minutes; I assume due to the engine cooling. When cold it holds 15psi for an hour without any loss.
It seems to me that I don't have a coolant leak but she'll drink a gallon of coolant in 20 miles.
Any thoughts on how the coolant is getting to the combustion chambers without a coolant leak?
I'm not an expert on this, but my first thought is that your water pump may be the cause of the pressure/fluid loss. Also, maybe there is some air in the system that has played a role in the symptoms. In any case, hope you get it figured out. Best of luck.
OMNISCIENT (07-02-2013)
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Interesting, glad you got it fixed.
cycdaniel
12-17-2019 10:58 AM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
