Cheapo blue clock mod
Korean FIYAH!
I don't want to get in trouble with a 97er or a 98er if their clock is wired differently. I've heard that on a 97 clock the wire to cut is the Yellow one. Don't take my word for it though.
Korean FIYAH!
If you look in the picture you can see that I cut the yellow and the white wires before I got around to the red one....
I just spliced them back together and electrical taped them back up. Those wires are not under any tension so it isn't a biggy.
Klepto, ask DanMan. He is the one who told me to cut the yellow wire on a 97. You may want to PM him to double check though.
Saucin
cant you just pop that part that clock is in out with out taking it all apart? i did it before, its not hard, stick a screw driver in and pry a bit and then itll eventually pop out of the pins or w/e they are. and i right?
Korean FIYAH!
That's because the 97 center console is cheap as dirt. ^_^
The 98-99 clock is screwed into the center console. If you look at the step #13, you'll see that to remove the clock you have to unscrew 2 screws.
Ahhhhhhhh
Good news every 97er out there! I decided to take a bullet for the team and test it out. I tried the red wire because I had two yellow ones and it worked. I don't know what everyone elses wires are colored but just look at musulsa's wires that he cut. Remember the position of the wires. When the plug is facing you, it's the second one from the right. Thanks Musulsa for testing it out for all of us, and also for the awesome DIYs.
Can anyone give a DIY to remove the center console for a 97 CL... I had all the screws out and I think it's screwed into the metal bracket below the deck? I don't know.. any suggestions would be great
Originally Posted by Vidman213
is the console removal the same for those of us without woodgrain?
Originally Posted by KLepTo
yes, the woodgrain is just a plastic overlay for aesthetic purposes only. I dont know if you have a 97 or not but if you have a 97, all you gotta do it stick a small flathead screwdriver and pop out the square plastic piece that goes around your radio and pocket underneath
Saucin
Originally Posted by LLWesMan
Pics.
if you look, theres the little black ring around the cdplayer and stuff, unlike the 98's, we only have to pry that off and its super simple
i just did my climate control as well as my clock
i got this blue tint thats sticky on one side... its like the same thing as dasani but sticky on one side.. and i used an exacto knife to cut it perfect and stuck it on.. it looks AWESOME..
Ahhhhhhhh
yep.. i used another type of blue tint.. its perfect for the job.. i dont know what material it is .. i got it from this local art store that found it outta nowhere.. and they didnt even know what it was... i can cut out the shapes and send it to you .... all you guys have to pay is the shipping which is probably like 2 dollars.. its like a sticker tint.. its really thin.. just like dasani but sticky on one side..I got pics
let me upload
let me upload
yea so what i did was i cut out the shape of the clock/climate control...
and i made it exact with an exacto knife and stuck it on perfectly like a tint.. and it came out flawless...
you dont have to remove anything.. everything is stuck ontop.. and you cant notice it because its like a tint... and it goes on smooth
chiny-j --- the art store is on woodbine and danforth.. litterally right by the interesection...
you cant miss it.. its pretty big.. dont remember the name
yadadaa
DAMN NATO! that looks sick. did u use that tint on the clock too? it looks good. ill go look at some art stores around here too, hopefully that have some of that shit
Korean FIYAH!
Klepto, can you get this jackass out of my thread?
People are coming here looking for tips, not to see 17 year olds who weren't trained to control their tongues.
Ahhhhhhhh
what happen ?.. was someone badmouthing someone?...
yeap, klepto.. i'll send you a bigger piece too incase you screw up
Ahhhhhhhh
Saucin
Ahhhhhhhh
your thread huh? i do believe its kleptos thread and your DIY. not a matter of controlling tongues, i miss understood what he said and he was rude in a reply so why would i give him a have a good day?
