another seafoam question
vtec kicked in yo
convince me to do it and how to do it. i need to know lolz.....
i cannot find anything good on it and i need to convince myself and my father who owns one . anything would help even if its a con
takin care of Business in
Received 4,732 Likes
^^^ its pretty simple to do...and cleans couple things:
1> put half can in your gas tank which has about 3-4 gallons in it....this cleans the lines and the injectors
2> put a can in your engine oil case....this cleans the plugs and any crud in your engine....i recommend doing an oil change in the next 100-150 miles of doing this....
3> put the remaining half can in your vac port using "sip sip or slurp slurp" technique....this cleans your TB/Manifold etc....
after this go for a nice drive....hit vtec couple times....
do an oil change the following day....
enjoy higher mpg's....
vtec kicked in yo
^^^ yeah i do the 2 can stuff every 5K miles when i do an oil change....
otherwise i would just put 1/2 in fuel tank and 1/2 in vac port....
vac port in not the PCV valve...it is the vac line, refer to this video:
http://www.youtube.com/watch?v=dQ1wpO6Oj8E
vtec kicked in yo
http://www.youtube.com/watch?v=F0isyGBCngY&list=FLIMJZBUW0QeMA_SHXOTVtFg&feature=mh_lolz
^^^ what year is ur car ?
i dont much about older cars....and u can put as little as you want....depends on how much cleaning you want (dont put 5 cans of this in there saying you want it sparkling)....
i go by the stuff i said, i wudnt put more than that....instead of 1/2 if you want to put 1/3, be my guest
vtec kicked in yo
LOL then go by the video....
antonio3rd (12-02-2011)
^^^ yes....if you put the oil in the crankcase....it is advisable to switch ur spark plugs...
but if you put it in the fuel tank/vac port no need to switch ur spark plugs....
I used to do seafoam every 5K miles with 2 cans (1/2 fuel tank, 1/2 vac port and 1 crankcase) and switched me spark plugs ONLY the 1st time i did so....every other time i didnt switch my plugs....
thanx for the advice...
but whats a crankcase?
also can somebody tell me which spark plugs are decent for my car?im not looking for racecar parts etc...just reliable product..
thanx all
thanx all
^^^ crankcase is where you put ur engine oil....
I would go with NGK's Laser Iridium....they are good for 80-100K miles depending on your driving conditions/style....
They are about 7-8 bucks a pop....Advance Auto Parts has a deal when you spend $75 you save $30.....pick em up there (coupon code is BIG30).....order online and either pick up from store or free shipping on orders more than $75...
acuratl26
04-23-2020 07:30 PM
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
